Tade '06 R for X?
I have managed to damage my left ankle and right achilles tendon and am looking to possibly trade my perfect '06 CRF 450R for an 06 450X or KTM 450XC.
My bike has less than 4hrs, was broken in carefully with 3 heat cycles, practiced on twice. I then had the valves adjusted, greased the linkage/swingarm/axles and put on new D756's. Caught my foot in a rut in the 3rd turn of my first race on the bike at Budds Creek and the bike has been parked since then...
Need a button now!
I live in Southern Md...
If interested, pls eamail me at magua93@yaoo.com or pm here.
hmm... If you were alot closer id trade straight up instantly. you willing to drive? :thumbsup:
Well, maybe... depends on the bike and the distance...
its a LONG ways away. and seeing that my bike already blue books for more and its an 05 and its already modded that i'd still be losing money. If your willing to do all of the driving, just let me know whats going on and we'll trade straight up. the jetting is just getting dialed in on this bike and its a perfect bike. im probably one of the few in the 450X forum that has less than 250 miles on the bike.
If your actually interested just talk back on here or give me a PM. :thumbsup:
I'm gonna have to disagree with you on the book values...
Check your PM
mine has about 30 miles on it!! :thumbsup:
mine has 32 miles on it....
30 and 32 miles. When did you get them? An hour ago....
haha serious..i did that just goofing around on a 100CC or less track haha got kicked out after about an hour for my bike being to big lol
actually one week ago. I will be racking up the miles here in no time!! :thumbsup:
Mine is still not completly put back together, mine is a supermoto, and I rode it with the stock sprocket and brake and didn't like it so I am waiting for the parts to get here!
Only have 78km's on mine so far! Still snow on most of the good riding areas around here.
  • Similar Content
    • By cmckay4
      Anyone having or had problems with the starter not turning over easily on the 450X???
      I have read about this problem on CRF's ONLY and not seen anyone come up with a fix.
      Problem being is that you think there is a problem with the battery, when infact the battery is OK. When you have a good fully charged battery in the bike and press the e-start, it turns over very slowly.
      I have checked the electrical circuit and it seems OK. I am wondering if it might be the starter itself - any suggestions?????
    • By Dust_Devil
      I'll start, if you see the "Fox Sticker" out in the Dez you know you crossed paths with ol' DD.....
    • By JohnnyAirtime
      Guys and Gals...
      Post your links to any of your pictures in this thread....
      (proper placement of pictures is in the "picture" threads)
      Post your links to any of your ride reports in this thread....
      (proper placement of your ride reports is relative to the area you live/ride)
      NO TECHNICAL issues, questions or comments in this thread.
      (it'll be deleted to keep this thread clean and with only the above listed).
      Please follow this format;
      Ride Report: Gorman, Tuesday 4-17
      (by Skoot22)
      Pictures from Ride: Baja 4.14.07
      (by Johnnyairtime)
    • By dakynz
      Guys, because of a member ban the jetting database has been removed. Let's start a new one to get this great information created into a sticky for everyone's benefit. Please stick to the information below.
      Temperature Range:
      Smog (AIS):
      Airbox Modified Top:
      Airbox Modified Sides:
      Backfire Screen:
      Air Filter:
      Pilot Jet:
      Main Jet:
      Needle Clip Position:
      Fuel Screw Type:
      Fuel Screw Setting:
      AP Modified:
      Leak Jet:
      AP Cover:
      Exhaust Type:
      Exhaust Modified:
      Pink Wire Modified:
    • By 2can
      I've studied the Jetting sticky's but still have a number of questions:
      I bought my '06 a couple of years ago and had a smog block-off kit installed and the pilot jet was upsized to a 48 and the air box opened up top only. The bike has appeared to run a little lean at times and got hot on a couple of occasions in elevation and on one other occasion. I'm looking at upping the main jet to either a 165 or 170 to help with the possible lean condition. The bike currently has a 142 main jet in it which I believe is the stock size. It looks like the most widely used Needle Jets are the JD Red, but it doesn't look like they are sold separately, is this correct?
      I was going to also get a 45 pilot to have options for further tuning. My assumption is that every bike is a little different and that where you ride is going to have a lot to do with jetting. We ride mostly, mojave desert, baja, and southern Utah with elevations from sea level to 9,000 feet but the higher elevations are generally for a short period as we generally continue through the peaks and head back down.
      I'm looking to convert from a stock exhaust to possibly an FMF Q4. I want something a little throatier but not overly loud and will provide a balanced flow of intake/exhaust.
      So can I get the JD Red Needle Jet by itself or can I get by using the stock and move the clip and be just as happy. I'm just looking to enhance overall performance of the engine and maintain reliability.
