Muzzy Ti System on 400SM
I want to put this system on my new 06 400SM.
I understand these pipes are for the "E" model.
I've read here that the "E" pipes fit the "S" models and SM by adding a longer bolt where the rear passenger peg mounts.
From the pictures I've seen I also wonder if the exhaust outlet is going to interfere with the turn signals.
I want a Titanium pipe that doesn't cost 7 large, and the Muzzy looks like the ticket.
Anybody got one of these on a SM that hasn't had to swap out the subframe for an "E" model?
I put an E model RS3 on my SM. No problems at all, fit perfect. Had to cut the mounting bolt at the rear pegs down some threads and loosen the 2 bolts that mount the rear peg to the subframe, but the rest was a breeze. I like the way the E system looks better on my bike. Not sure about the Muzzy but the Yosh E model has no heat shield and looks super clean.
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
