Installed some upgrades today
Today I worked on my "S" and it still needs a bit of tweaking. I first checked the valves and installed a new spark plug. Then installed an FCR-MX with Flow Commander 2000 and an E Air Boot. Topped it off with an RS-3. Still waiting to be opened are the kickstart kit, and a mcct. The bike fired on the first push of a button using all of the recomendations that came with the FC and the extended fuel screw. However at a few stop lights/signs it died, push of the button and we're off once again. Hopefully the weatherman is accurate for his forecast tomorrow and I will attempt to fine tune the set-up.
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
