Where is the oil filter on 2002 MXC400?
I purchased a 2002 MXC400 from a dealer and did not get an owner's manual. Can someone tell me where the filter is?
Thanks in advance
On the top of the transmission case, you need to remove the brake reservoir (one 8mm hex screw) then there are two small covers, each with two 8mm hex screws.
If you go to KTMTalk.com at the top of the page click on "shop online", then select year and model and you can see parts catolgue
