Happy Holidays
I'm in the holiday spirit so I thought I'd pass on the greetings from Phoenix, Az.
Everyone have a happy Thanks Giving and a Merry Christmas. If your traveling for the holidays be safe and keep it under 100mph.
Take care...Rob and Mindy....
Same to you. I can't wait for that thanksgiving turkey. :)
"keep it under 100"? I have to, my Powerstroke is goverened not to go over ~95 :)
Happy bird to you and your loved ones.
Yes..happy holidays too you all.
Even though we are hosting the biggest thanksgiving dinner ever...Not so sure I'm looking forward to 48-50 people invading my new house this year.
I'm going to end up standing in the corner eating my dinner off a paper plate...yummy.
i dont come here much to talk but i love the info i get here. happy holidays everyone
and to all a good night
And may visions of DRZ's dance through your head.
And I Wish You All The Best Over The Holiday Season :D:):D:D:D:D
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
