Suzuki Canada website typo
FYI the 02 models are shown on the updated suzuki Canada website.
i see we get a choice of yellow or blue this time and the sales blurb still has the same typos as last year such as....
The DR-Z400S and DR-Z400E models use a Keihin FCR39 flatslide carburetor.
Wonder if i should write and ask for my Keihin? :)
[ November 20, 2001: Message edited by: dendrz ]
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
