Hey "mnelson 78" part #'s for FCR conversion
Here is the total parts list needed for FCR conversion:
Part # Description
13111-29F00 Intake $30.62
13278-29F00 O-ring, intake manifold $11.93
13685-29F00 Union, intake manifold (2) $13.38
13670-29F00 Keihin FCR velocity stack $71.03
09402-58208 Clamp $5.99
09402-60208 Clamp $4.99
58301-29F00 DRZ-400E throttle cable $106.34
13881-29F00 Airboot DRZ-400E $95.24
13200-29F40 Keihin FCR carb DRZ400 $1351.00
Total Cost: $1690.52 (Canadian Dollars)
Hope this helps anybody.
[ November 26, 2001: Message edited by: Wolverine1 ]
Hi there,
Just curious, how much is the total cost for these parts?
Thanks! This will really help.
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
