Dirt Bike Expo Coventry
Anybody going to this, Ill be there tomorrow
Keith, I just got back from the show and the first thing I am going to say is why should we pay £10 to look at products Manufacturers are trying to sell us?,no courtesy bus from the car park 3/4 mile walk in the rain! and if like me you are looking for a bargain in the trade stands, you'll have to look very hard, only Off Road Only ever seem to do good deals at the shows I attend.
Any way "bitchin" over, some nice bikes (KTM) and bits to look at and a good freestyle jumping display outside :)
:) Keith, I'm going on Sunday so let me know what it's like please :D
Nice to see someone from Knaresborough as well on these forums! :D:D
Just got back, M1 very slow on the way home 3 1/4 hours. on the way there 2 1/2. Good show, plenty to see. Great freestyle action outside and more. As last year there was floods of people walking out with the £20 bike stands including me. Spent more than i intended but when the mood takes you. The Honda CFR450R seems to be the bike there all talking about. I was tempted by the KTM Duke but at £6000 i dont think my wife whould be to impressed. But it was good to see that the DRZ was voted MCN trail bike of the year.
[ November 30, 2001: Message edited by: UK Keith ]
:) Glad to see it's not just me who has problems with "er indoors" he he!, I will probably have to hide some of the items on my "Shopping list" after Sunday :D
  • Similar Content
    • By Markl5557
      So I am going to put in an in-line fuel filter just for added protection from stuff in my gas .... and I have always used bronze element cone ones you no what I’m talking about the ones everyone seems to use but upon reading online supposedly that bronze element breaks down and doesn’t catch everything .... I have came across a moose fuel filter that has a fine nylon mesh just like what’s on the petcock filter ... any opinions on which is better ? Bronze element or mesh ?
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
