What is stock exhaust worth?
I have a full exhaust system for an E that is just taking up space. No dents or anything like that. What would be a good asking price and is anyone interested in it?? Oh, by the way it is UN-modified(no end cap mod) if that makes a difference. Thanks
I sold my kicker system for 125.00
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
