Intial Modifications, some thoughts-long
I've only been reading this board for a couple weeks and got some basic ideas for some intial mods for my DRZe. Of course I looked for posts to learn what had worked for other owners.
Got some jetting ideas, read about removing the
coast down diaphram EPA item and the black crankcase vent box.
Good info all, buts lots of details left out.
Like you have to remove the pipe to do just about
anything on the left side. And the Carb is very
tricky to get out and involves removing throttle
cables, pink vent hoses, the electrical box on
the left frame rail (don't know what it's called)
unplugging the TPS and a bunch of other stuff I
can't remember. Finally got it out. What a PITA!
Many posts here about removing the snorkel
in the air box. I assume everyone means the entire
air box rubber cover which has the snorkel built
into it as a unit? NO one has ever expressed this
little detail. Sure, I could just CUT OUT the snorkel or do the obvious; revmove the whole
COVER. It's an entire rubber cover guys, not a snorkel alone per se.
And what about the back fire screen? No one has ever mentioned this.
On other bikes i've had the backfire screen was the first thing to
go, very restrictive. Any thoughts on this? (it is located on the other side of
the air filter. It is a metal screen.
Anyway, went with a 155 main, depite the consensus here
being a 165. Seemed like too big a jump to me with a stock pipe
and my friends at FACTORY here in San Rafael where
I live agreed. They sell jet kits and other stuff and
have Dyno tuned several of my street bikes with
great success. They are currently working on a jet kit for the DRZ.e
I went with the 48 pilot, which Suzuki does not
sell or offer as an alternate jet. Factory of course had it.
I guessed on the air screw setting and went two
and a half turns out. Anyone have any brilliant ideas for doing
the air screw adjustment with the carb on the bike?
Lowered the needle clip one position (thus raising the needle),
the needle now resides one position up from the bottom.
(stock is right in the middle)
The accelerator pump acuating arm came out with
removal of the float bowl, luckily I read one
owners experience with this problem and was able
to get it all back. Almost impossible to do with
carb on the motor. Carb must come out!
Funny, never read this little tid bit anywhere.
I'm sure I must have missed it. You could damage the carb
attempting this and scratch the **** out of your frame rails.
I'm really put off by all the pink vent/drain
hoses used by Suzuki. Anybody figured out a way
to simplify all this crap? What a mess!
I used a great photo posted on the board to cap
off the coast air injector diaphram thing and
Tee'd the crankcase vents and ran the hose down by
the shock, avoiding the pipe. I will come up with
a cleaner, less cumbersome route and method for this in future.
Crankcase vents should not be plugged, AKAIK.
I also hate Suzuki's idea for the radiator coolant
overflow tank. So much so that I decided to move
it. Can anybody guess where it now resides?
This thing is almost useless, even in extreme heat
it barely contains any fluid. In a way you don't
really need it at all. I'm tempted to toss it
and just be sure to check my coolant before every
ride like I've done on 20 or so two strokes I've
owned over the last 20 years.
I expected the bike to run poorly but I was
really surprized to find it runs great! Wheelies
in first 3 gears, and that is something it never
did before. Have yet to really do a long ride so
final verdict must wait, but I am hopeful. It was
a little cold blooded on start up and stalled once,
but throttle response was very crisp and power was great!
I have stock pipe on at the moment but will soon
go to am FMF, so I may go a little richer if need
be. I want to run as lean as possible and still
be very safe. Plug checks to follow.
Please detail any mods for the not so bright among us and I will try
to do the same. The carburator on this bike is one of the most
complex motorcycle carbs I've had the displeasure to mess with.
Can't wait till fuel injection!
Cheers, Patrick
San Rafael, CA 01' DRZe 01' KTM Duke 2 99' Tiger 95' Tiger 86' Reflex R6 on the way
Patrick,
Could
we
please
not
have
all that damn space in your message???? Scrolling is about as fun as picking splinters out of your ass after youv'e taken your DR-Z on a sight-seeing tour of the local BRIAR-PATCH!!!!
Sorry about the double spaced post! I wrote the
message as an email and pasted it in. Aol did it. It was my first message to the board. Won't happen again. I can't stand writing in the provided dialouge box. Very hard to edit/review this way.
Also very slow and tiresome to read board messages
with my 56K dial-up modem, a mailing list is
much faster and easier.
Cheers, Patrick
Prof.Moriarty,Have you did a search in the old drz400 misc forum?ThumperTalk lost a bunch of the old "detailed" topics a few months back when something happened to the forums,so we lost a lot of good info.Yeah,the backfire screen had been mentioned in the past and most people (then)thought it was best to leave it in place.If you do a check on the topic "fuel screw" you should find a lot of different opinions on the easiest way to get too it.Welcome aboard! :)
Patrick,Check out the "I tried again and failed" post I brought back to the top.CaptZ in the thread gives a pretty good (easy)wasy to get to the main,pilot,and fuel screw with the carb still on the bike.
Thanks to Tenn. Thumper for re-posting the carb
thread and to Capt. Z for the detailed account'
of carb removal.
I figured out most of this stuff along the way,
never thought of removing the sub-frame though.
It is much nicer with the black smog box gone.
And of course the coast/air injection EPA thing.
Still wondering if anyone has any ideas for eliminating or simplifing the pink carb vent/drain
hoses. These things bug me.
Still waiting for someone to guess where to mount
your coolant overflow tank.
Thanks for the help!
Patrick
San Rafael, CA
You guys are brutal....but it is kinda annoying...is it really that hard to change the jetting...A friend of mine and I will take the challenge this weekend...ordered a 48 pilot and a 165+170 main jet...Only have 105 miles on a new 2001 drz 400e and i want more bite....
