drze graphics
any good websites for wicked graphics?
How about graphics for the bigger tanks 4.2 gal.
Hello all im new here. Glad to be here. FMF has some great graphics. I dont know about the 4.2 tank for the graphics. I emailed them few days ago to see if there graphics would work on the new Acerbis 4.2 tank. Graphics w/seat cover is $129.something not bad.
I have some pics of my IMS 4.2 galllon tank. I picked up some graphics from the guys at IMS and I really like them alot. The customer suervice was, as always, superb. Take a look. Here is my photo page on yahoo. the pic may not show up here.
[ December 09, 2001: Message edited by: SchlepRock ]
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
