Chambon in a SM race in France ...DRZ 400 E
11.jpgThis is not my bike!!!! But I was just surfin and found this E chewing at some pavement!!!
web page
[ December 04, 2001: Message edited by: WILD FX ]
COOOOL! Showing plug, drain plug that is. :)
I can see it nice pic, i can almost hear thos tires :):D
Note the holes in side cover for air intake, i wonder if that is the same as Sunny mentioned he done to his?
Used to sneak up to Westwood race track early in the morning on my '80 YZ400 and just giver around the track, was a rush! Full knobs and all!
Originally posted by Wobbler:
Used to sneak up to Westwood race track early in the morning on my '80 YZ400 and just giver around the track, was a rush! Full knobs and all![/quote
WoW!! I only dreamed of doing that. When I moved here Westwood was gone! As a kid I always wanted to ride the streets (most of the time with lights and sirens behind me :) )
And for some reason I still do, but now the cops don't chase me as often now :D
I had grew up riding in bush trails and open pits, there was very little pavement so now it is such a rush gettin side ways on the black top I don't want to stop :D
  • Similar Content
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
    • By drzvfr
      I did the fix last night and took some pics and notes to make this easy on people that haven't done it and want more detail. Please chime in if you think I've missed something.
      Required Tools:
      Set of Allen wrenches
      #3 Phillips screwdriver
      small flat head screwdriver
      8 & 10 mm sockets
      13 mm open end wrench (I needed this to remove my skid plate)
      snap ring pliers
      gasket scraper
      compressed air
      Required Parts:
      New clutch cover gasket, Suzuki Part # 11482-29F00
      Tube or can of RTV sealant
      Oil filter and oil (if you plan to change the oil)
      1. Remove your skid plate (if you have one). I have a Tonn's skid plate and it was in the way.
      2. Remove right side radiator cover.
      3. Unbolt the rear brake lever. This will require removing a cotter pin on the backside of the bolt, and then the bolt itself. I was able to swing the lever far enough out of the way without completely removing it from the bike (see pic).
      4. Drain the coolant. This requires removing the radiator cap and the small bolt on the water pump, which has an aluminum washer on it. I rocked the bike from side to side to get most of the coolant out of the bike.
      5. The oil, two options here. You can either drain the oil and remove the oil filter or you can do what I did which is lay the bike on its left side to keep the oil from pouring out of the engine when you remove the clutch cover. I still removed the oil filter so I could clean the clutch cover with brake clean after scraping the old gasket off.
      6. Loosen the hose clamp on the coolant hose that attaches to the top of the water pump and fold the hose out of the way.
      7. Remove the water pump cover and the clutch cover by removing the bolts holding them on. Note that some of the bolts are of different sizes so keep track of which hole you pulled them from. Also, not all of the bolts need be removed, see the pic below.
      8. Remove the old gasket from the clutch cover and/or the engine with your gasket scraper. I then cleaned the clutch cover with brake cleaner as it was fairly oily.
      9. With your snap ring pliers, remove the snap ring from the plastic gear on the clutch cover seen here:
      10. Remove the plastic gear.
      11. Push out the metal pin and remove the washer underneath as seen here:
      12. With a screwdriver or whatever your preferred tool, remove the “E” clip as seen here:
      13. After removing the “E” clip push the water pump shaft out of the clutch cover.
      14. You will now have the part in your hand that needs fixing. Remove the porcelain gasket at the bottom of the shaft by blowing it with compressed air. Don’t not pry it with a screwdriver as it could damage the gasket. Mine was stuck fairly well so I sprayed some WD-40 on first to loosen it up.
      15. If you used WD-40 clean the shaft and gasket with some brake cleaner and then apply the RTV sealant to this area (I reused this pic as its perfect):
      16. Push the gasket back down flush on the shaft wiping away any excess RTV that may flow out.
      17. Reassemble the shaft into the clutch cover in reverse order as listed in steps 9-13.
      18. Place your new clutch cover gasket on the engine and then place the cover back onto the bike.
      19. Put the bolts back into the clutch and water pump cover and tighten equally. I could not find a torque setting for these in the manual so I snugged them evenly.
      20. Put the oil filter or a new one in the bike and put the oil filter cover back on.
      21. Re-attach the brake lever and tighten the bolt to 21 ft lbs. Be sure to install a new cotter pin on the backside of the bolt.
      22. If you drained your oil, refill the crankcase with the proper amount. If you didn’t drain the oil be sure you have enough in the crankcase from oil lost from removing the clutch cover.
      23. Let bike sit for 24 hours to let the RTV set up before adding coolant.
      24. Re-attach the coolant hose to the top of the water pump and tighten the hose clamp.
      25. Fill the radiator with a “Silicate Free” anti-freeze and put the radiator cap back on and tighten the radiator cap screw.
      26. Put the radiator cover and your skid plate back on the bike.
      27. You are done, go ride!
      This post has been promoted to a wiki
      Since I've been getting a few requests a week to e-mail the re-jet instructions word document (offered to send it to someone in old post that lives on) I thought I'd throw this post together. It is perhaps the one stop shop for 3x3 mod info: the master 3x3 post
      The 3x3 Mod
      So what is the 3x3 mod anyway? Well, this mod is basically re-jetting your carb and allowing it to run to its full potential. This mod can be done by even the most newbie of wrenchers out there. 3x3 refers to the size of hole that you will need to cut into the top of your airbox where your snorkel currently is. Don’t worry, you are not carelessly risking getting water into your engine by removing the snorkel. The bread and butter of the mod is the taper of new needle which you will get with your kit.
      Jet kits can be found through the TT here
      Scroll down to the bottom to find the right kit for your DRZ
      If you purchased a S kit for SM by accident don’t worry it will work (different jetting specs are used, just ask!)
      There are some great instructions outlining the procedure and here are two:
      bayoubikebruiser’s post is a nice one (Good Job BBB)
      Note that BBB followed the TPS sensor wire back and detached from the clip it there rather than removing the TPS off the carb.
      Another read is the attached word file (which i convereted to pdf and can be found here for your convenience) which has ‘been around the block’ to say the least.
      Sample Jetting recommendations (note: these are different for different elevations and different bikes)
      - 150 main jet (155mj for full exhaust system)
      - 25 pilot jet
      - 2nd clip on needle from top
      - 2.5 turns out on fuel screw
      - 140 – 142.mj (bigger for exhaust)
      - 25 pilot jet
      - 4th position from top
      - 2.5 to 3 turns out on fuel screw
      Burned’s fuel screw setting method:
      with the bike warm and idleing turn the fuel screw in till the idle drops/misses.then go back out till the idle peaks/smooths.
      this should happen between 1 and 3 turns out.
      if you end up at less than 1 turn you need a smaller pilot jet.more than 2.5 (or 3 turns on a cv) you need a bigger pilot jet.
      choose the appropriate size and retest.
      The 25 Pilot jet part number for TT is:
      So… now you have the info that you need, get to it! Your bike will sound better and rip a little faster; get ready to grin!
