400 E 2001-2002 whats the difference
My riding bud bought the 2002 E model 2 weeks ago. At first inspection next to my 2001 E.
1.The graphics are a little brighter.
2.The Right side radiator bottom has to nipples
to hook the hose to instead of having the one
peace rubber,
3.There is a midrange valve ajustment for the
rear schock.
Anybody else know of any changes or improvements?
The list price here is still about $5400 and they ain't budging.
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
