weight of IMS 3.2 gallon tank?
Does anyone know the weight of IMS 3.2 gallon tank?
Anyone have any problems with this tank? I know it is more expensive than the clarke, but I think it looks a little better.
Looks like it can be setup as a dry break also but.. It says electric only so it doesnt have a kick slot molded into it for those that add kick kits later on. As for weight the added plastic isnt the factor it is the fuel capacity.
Gasoline comes in at 5.27 LB/GAL based on a document I found on web. So figure it out.
3 gallons is 15.9 pounds and so on.
Has anyone purchased the Acerbis tank? Looks good in the picture but it is not mounted to a bike. How is the fit?
I'm more interested in the smaller 3.2 gallon tank, as the truck is usually close by. I feel that the weight of the plastic is important because I am going to put the same one gallon of fuel in, regardless of which gas tank it is.
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
