Its looking good,
WildFX, simply put, AWESOME. I love the gold hubs with the blue rims, it's bitchen. Do us a favor though, give us a clear shot. My eyes ain't what they used to be. :)
Lookin' really good!!!!!
[ December 05, 2001: Message edited by: DR400rider ]
Class act!
I must be drunk cuz everything looks fuzzy :D:)
hehe, actually that looks really cool
Looks like you need new knobbies tho...Should we start the "What's the best tire to buy" thread. What do you have to do to wear down tires that bad and evenly...
'01 "S"
Dam NEW cam I got is fkd ,all pics are blurry :)
So im gona do it the old way and scan some tomoro night of the roll I just shot. I droped the forks off and pulled the old head light off. put some of the stickers on.
Im tired now :D must sleeeep arrrghhhhh!!!!!THANK YOU ALL ---------- MORE TO COME!! :D
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
