Clarke Tank (Blue) For Sale!
I was going to keep it for Baja trips. But, it's taking too much space in my tiny garage. I only used it about 5 rides before I switched to an IMS 3.2 . . . I figured I didn't need the extra gas and I like the fit of the IMS better. $100.00 firm, plus shipping (from 92663). My loss . . .
What colour IMS tank did you go for. Was it blue? does it colour match ok? was it designed for the S or E how is the fit? All this info would help me.
I'm thinking of going to a plastic tank because i don't want to dent the steel one when going off road.
Also does anybody know of a supplyer in the UK for the small IMS tank.
If UK Keith does not want it i will take it if it comes with filler cap.
Rock check your email
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
