Extra set of rims.
No guys I don't have a set for sale,just wanted to know how much they would cost?
Geez Wally, that was an evil trick!
Would'nt we all like to have a spare set o'rims.
I do not know what the factory style costs, but aftermarkets are not cheap. I looked at a set of excel's the other day- $500 laced to a compatable hub. Too rich for my blood :)
I priced a spare rear wheel complete at my dealers just out of curiousity.
Rim complete with hub spokes and disk $1133 Canadian.
That does not include your choice of tire and sprocket.
Wish we could find a suitable second hand source?
There are two motorcycle salvage lots here in San Diego. That might be a place to look for rims. I would love a rear, so I dont have to switch from paddle tire to dirt tire.....erik
The person that posts on here that a 95 whatever yamakawihonda bollide rear wheel is an exact match for the Drz......
Will be nominated for sainthood
Thanks for the info guy's just the information I needed,looks like changing Trailwings to Bridgestones with a tire iron.Too rich for my blood.
I got a set from a guy that went Excel/Talon for his "S",
I paid $500 for the front+rear+brake disk+tires+tube+rearSprocket.
I'm happy, now I got a set of each street and MT21 wheels
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
