Engine Ice ?
I just read on the CRF450 page about people using engine ice in there bikes. What is it and has anyone used it in a DRZ.
Yo MD, or should I say MF?
Check out Engine Ice's site at http://www.cyclelogic.cc/. It's supposed to lower the operating temps up to 50 degrees and eliminiate boil over essentially. They have a pretty cool FAQ section about the stuff.
Haven't used.
Thanks buddy, Went riding at Hollister today. My water pump is leaking again.
I'll see if Zoom or Honda has some. I want to try it out.
I have tried engine ice it has help in the prevention or over heating more than Water wetter but in slow steep areas I still over heat. I am going to try rejetting over the winter and see if that helps.
Thanks, I'll be triing some after I change my water pump seal.
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
