This has been a great bike and it is in excellent shape....I NEED TO GET 4200.00 ....payed 5900.00 out the door last January..I just purchased a KTM 520 AND MY SON NEEDS ANOTHER BIKE OR I WOULD PROBABLY KEEP THIS JEWEL...AS ALL OF YOU KNOW THIS BIKE IS VASTLY UNDERATED.....THE only problem I had was the weeping water pump seal that has been fixed by the dealer....do not use automotive antifreeze...the silicates will damage seals in the pump area....call if interested ..I am in Tracy ca. 209 836 4833...ask for Ron
Do you have a green or red sticker or a plate?????????????????????????????????????????
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
