Fork Oil, which kind?
which fork oil should I use for my drz-s.
I'm going to add 20cc's to each fork like suggested.
StarKist 6oz. :)
Gyro: If you are just adding a little oil any old ATF will work. It is all hydraulic fluid.
The stock stuff is 5 wt and is a little on the light side so a few OZ of 10 wt ATF will not make much diff. That is a cheap way to experiment. When you decide to flush and refill then you may want to go with one of the brand name fork oils or some say Mobile 1 Synthetic ATF is best fork oil going. It is now up to $6 a quart but still cheaper than many fork oils and sold everywhere.
I used some 5w
worked good
I don't plan on staying with the stock forks/shock for more then a year from now.
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
