Just went by my local shop, where I bought my bike. And what before my wandering eyes should appear, but a brand new -2000- "s" model. A yellow one. I bought mine (a 2000 s) in May, and thought that was the last 2000 they had. Well, sure enough, they were assembling this new one today. It was all coated with dust like it had been sitting in the warehouse for a LONG time. They've had several 2001 yellows and blues for sale through the summer in their showroom. Guess they just never had room to display a leftover until now, since they now have no '01 and '02 models in their showroom.
So...... If anybody is looking for a deal on a new bike in the Chattanooga area, check out RT Cycles - they may be ready to deal.
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
