Carburetor Parts Warehouse - E carb on S kits!
I just ordered a complete Kehein carb kit for my S. The kit comes with everything I need to do the conversion, $485. They said they sell 4-6 of these kits a week for the DRZ400S!
How many of you TT members have done this conversion from Carb Parts Warehouse? Any problems? Do you like the results?
I sure like to hear from those who have converted! Before I did the Thumper racing mods I was so close to replacing the CV on my S.
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
