What happpened? :)
Cool :D
Originally posted by dendrz:
What happpened? :)
Cool :D
Just a little color change to keep it fresh! :D
Extra kick with the coffee in the morning for some!! mahaha
i like it :)
Sweeeeeeeeeeeeeeeeeeeeeeeeet :)
I thought my computer was busted for a second! It will take a while to get used to! Looks good!
Thought I had too many adult beverages. A DRZ this color would look cool. :)
Cooool! :) and faster too. Or is that because it is 5:00 am, just thought I'd check in before going to work. :D
Same here. I thought my bad Karma had finaly caught up to me. A little easier on the eyes. I hope I can still copy and paste. I have been keeping a file of some of the good stuff you guys post.
I find it harder to read. I prefer to old color, but I'm not picky.
I like this new color.
I like the new colour and icons.
Good stuff TT.
Now if we could just get the index page for the DRZ updated yuck!
[ December 15, 2001: Message edited by: va3mod ]
I hate to be negative, but I find the new color scheme pretty hard on the ol' peepers. I think an update was in order, but more soothing colors might have been more effective.
The site does seem faster though, and that can never be bad thing.
Good stuff TT.
These "owners" pages are not going to look like this for much longer. Each page (WR, YZ, DRZ) is static html. We cannot make changes to each globally like the forums. For example, if we want to add the new logo, we have to add the image to the code for that page one at a time. More complex changes are time consuming. Since they will be changing dramatically in the near future, we are not going to waste any time polishing them. The entire site will be dynamic, allowing us to update the site faster. :)
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
