what speed can you get
What speed can i get with a sprocket ratio of 14
front and 44 rear. I race off road with a drz E on speedo meter.
You can get 100 mph or 160 km/h.
Got your message.
I have a program for calculating gear ratios.
14/44 sprockets with a max RPM of 10,000 and a 26inch tall rear tire using ratios for a 400E works out to
1st 2nd 3rd 4th 5th
36mph 47mph 60mph 76mph 96mph
Stock 14/47
34mph 44mph 56mph 71mph 90mph
36mph 48mph 60mph 76mph 96mph
looks like a front sprocket change to 15 would do about the samething and cost less :)
on second thought 1st is pretty tall already you are probably right in changing the rear. :)
What speed do u think one can get from a 1997 KDX200 with a 45 rear and 14 front sprocket(14/45)?
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
