2002 tail light
Do a search under tail light mods. I actually wired in a 270 ohm 1 watt resistor with a hydraulic brake switch, and turned my led light into a brake light. It works great. Its still not DOT approved, but it has helped me in a pinch. :)
the tail light on the drz e is l.e.d does anyone know where i can get one with the stop light in it aswell. be good if it was in the uk. thanks
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
