carb brand?
What brand carb is on the 400E? I want to order jets, but I am not where the bike is.
400E uses a Keihin FCR39SS
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
