yoshimura cam & ignition
I am considering installing the yoshimura cam & ignition kit in my 01 DRZ400, has anybody out there installed this kit & if so can you give me some information on performance gains?
Richard I have experience with the cams and ignition. You can expect an increase in mid range and top end power. You will gain about 1200 RPM with the ignition module before you hit the rev limiter. You will lose a little off the bottom with the cams but not enough you can tell. It is best to run their valve springs also.
