aftermarket gastanks
Does anyone know if you can buy aftermarket plastic gastanks for the 400E that are not the plus-sized tanks?
It'd be nice to get a plastic tank, same capacity as stock, but in a different color. Like, say, blue.
I think the closest you're gonna get is the IMS 3.2 gallon tank. It's only about a half gallon bigger than stock. I would doubt you can tell much difference.
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
