After Market Pipes with similar Db to stock?
Love the stock DRZ E stock pipes noise level. Can you modify any of the after market pipes with an insert to be close to the stock Db levels?
The QUIET system they have is about the same as a drilled out stocker. Otherwise the TEC Yoshi. I have the big gun... its 6lbs. lighter, more HP, better response, looks cool :)
I am waiting for new technology. I want quiet, light, and more power before I will give any money to any aftermarket manufacturer.
Untill then I will continue to use stock or modified stock exhaust.
The technology is out there they just need to get hungry enough to market the stuff.
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
