Welcome PMAUST...
Thanks for stepping up! Live long and prosper!
PMaust de man :)
Originally posted by ballistic:
PMaust de man :)
Thanks guys. Let the fun begin!
Hey PMAUST, Ditto...thanks for stepping up. I am from the Bay Area and noticed you are in EG. I have family up that way, we should hook up for a ride! :)
I see BillZ is back too.
DRZ400Vet, I look forward to meeting and riding with you. Anytime you want to hook up send me an email. I am also willing to drive out your way. Thanks, Paul.
Good to have you here! :)
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
