service manual
Does anyone know of a good service manual for the drz400e. Not the manual that comes with the bike, i would like one to be able to make reparations and service such as adjusting valve clearence. I would also like to know where to buy the manual on internet or mail order.
Magnus, just ordered one. They are $70 plus shipping, ouch, but cheaper than a mechanic, hey. A couple numbers I found on the net are 1-800-860-0686 and 1-800-888-3084.
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
