WER steering damper
has anyone tryed the WER steering dampner?
very interested if it works!?
I like how it sits on the front fender.............out of the way. I'm looking at the GPR and the WER.
I used the WER damper on a GSXR 600 for a season or two. It worked great. I've never used one on a dirt bike.
2002 DRz 400 S
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
