to anyone who lives on south vancouver island
im looking for a few guys {5-20} with 200-650cc streat legal enduros with nice tires.
planning a few short and a few long rides. nothing too tight because of the 650s, mostly old logging roads with big washouts and snow.
almost everyone will be a stanger to everyone else and it is always fun.
i will be on my 1992 dr650s {i like the extra power for the highway and long hill climbs.}
please email me if you want in, i will NOT be checking for replys on this site.
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
