substitute circlip?
After breaking a leg at Ponca , Ive been fidgeting with everything I can get my hands on, and in the process of doing a topend on a cr250, While wrestling around too get low enough to install the piston pin cir-clip I let it fly out into the backyard at night. I took the clip out of the stock piston and used it, but it seems a little lighter than the Wisco clip. Should I chance it? I couldn't drive the pin out with it installed. If it was my bike I would try it but I don't know
if the holes are the same you should be fine. But this is one part that should always be replaced. tis cheap. But this means no finishing the top end tonight
you should measure the wire diameter of the two clips to be sure . sometimes wiseco uses bigger wire , witch would mean a bigger groove than the stock clip is made to fit
