DRZ400E CA Model DJ kit
I just bought a 2006 drz400e CA with Mikuni bsr36 carb. Have read drz.info and read every thread and post about jetting and 3x3 mods to get some more power. I've noticed all the advice for the bsr36 is based on the stage one DJ kit for the S model. After looking at the Dynojet sight I saw that they now make a stage one and two kit for the CA E model. Also, If I decide not to use the DJ kit and just put in a 150 MJ and 27.5 PJ with 3x3 mod, do I need to mess with the fuel screw (It doesn't mention anything at drz.info)? Oh yeah, I did the 1 3/8" endcap mod already. I ride from 200' to 4000'.
Burned, thank you for taking the time to help out soooo many people!(Hint)
Eddie had me install 136 main 25 pilot DJ needle and 2.5 turns on teh screw. I ride WA state 1000-4500, runs great
I hope you'll tolerate a stupid question. I'm in the middle of installing a DJ kit to my 400S - which is the main jet and which is the pilot? Thanks for understanding.....
It is in the center of carb below the needle.At the very bottom of carb
if carb is in upright position.The needle points right to it and the tip of needle almost touches it
You still need to mess with fuel screw no matter what you do. Even if you
do nothing the bike will run better with properly set fuel screw
Thanks Steve - it was pretty clear once I got in there, but reassurance is good!
I bought the same bike and ride at the same elevations. I love my bike. I just wish it had a little more for power wheelies. So far I've managed to climb most all the hills in Hungry Valley. Just want to be able to wheelie when I blip the throttle in 2nd & 3rd. Let me know how you like the jetting and if the end cap made a difference. I was considering a yosh RS3 and jetting.
What is the 1 3/8 end cap mod.??
I'm going to put in a 150 MJ and 27.5 PJ with the 3x3 mod. and see how that helps before I try the DJ kit. It's a lot easier. I'll let you know how works out.
Use a 1 3/8" bi-metal holesaw to drill out the tip of your exhaust. Check out drz.info.
