ttr125 help
my ttr15 smokes and burns oil at high RPM it has a fresh rebuild on it and still does it.
Valves out of spec?
probably didn't break it in right. Did you check the ring gap or hone the cylinder. Put the "T" on the rings up??? Could be a lot of things.
Rings probably didn't set right.. Like SocalXR said, can be alot of things.
If it was the rings it would smoke all the time and not just at high REV'S
get new rings and try again...when ya get it broke in change the oil and try again...i put a good 5-6 hr on mine before i started ridin hard...still wasnt long enough..still smokes a little
