Rim width?
Will a 5" wide rear Excel rim & rad Eagle series hub Fit on a 2000 DRZ 400s?
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
