Different exhaust note
I'm curious if its my imagination or not, but does the exhaust note change if you switch from a 'S' to an 'E' base gasket?
I haven't done the mod, but if it raises your compresion ratio, as I've heard. I would think your exhaust note would change. Scott
The "Note" changes because of the increased combustion pressure!You are compressing the same amount of air in a smaller "Squish" (thinner gasket)= higher compression=more power=deeper note.
