cheap front signal mod
JDinLakeside, the link to the pic doesn't work anymore.
Do you guys have raised bars. My bike has stock bars and the front brake stuff on the right side is in the way.
Stock bars,stock perches,stock handguards,stock everything....no grinding,drilling,notching or breaking anything.All that is done is swapping the front turn signal brackets.The right goes on the left side and the left on the right.Same bolts,hole locations and brake line guide(inverted).The turn signals will be level and even with the widest part of the headlight shroud/number plate.Don't forget to properly tighten up the tripple clamp bolts(21.5 ft.lbs).
  • 5 months later...
  • Replies 62
  • Created
  • Last Reply
Top Posters In This Topic
  • 4
  • 3
  • 8
  • 4
