Jetting Sticky-450x
Lets compile a Jetting reference for our bike;
Needle /clip position
Fuel screw (turns out)
Leak jet
carb mods
air box mods
air filter
Pipe/ mods
Engine Mods
Altitude- Zero
Main- 170
Needle /clip position - Jd red / 4th
Pilot- 42
Fuel screw (turns out)- 1.75
Leak jet- 65
carb mods- Ap mod
air box mods- cut top and door not right side
air filter -Honda
Pipe/ mods- Running 450R pipe
Engine Mods- None
Altitude 1000-2400'
Main 168
Needle /clip position Red JD needle 5th clip
Pilot Stock
Fuel screw (turns out) ~1.75
Leak jet Stock
carb mods None
air box mods All openings open up
air filter Stock
Pipe/ mods Stock with baffle in (I took it out but cannot tell a difference in power with it in so I just leave it in)
Engine Mods Stock
Altitude 2,000-3,000 ASL
Main 165
Needle /clip position 4th
Pilot Stock
Fuel screw (turns out) 2
Leak jet
carb mods
air box mods. Snorkel off and side vents cut open
air filter Uni Foam Filter
Pipe/ mods Stock/Baffle removed
Engine Mods
Altitude 0-6000
Main 170
Needle /clip position middle(4th?)
Pilot Stock
Fuel screw (turns out) 1 1/4
Leak jet Stock
carb mods Magnetic drain bolt
air box mods Drilled 1/4" holes in side vents and pulled snorkle
air filter TwinAir filter and basket, no screen
Pipe/ mods Yoshi Carbon Fiber slip on
Engine Mods Stock but did remove smog, crankcase breather tube re-routed.
  • Similar Content
    • By cmckay4
      Anyone having or had problems with the starter not turning over easily on the 450X???
      I have read about this problem on CRF's ONLY and not seen anyone come up with a fix.
      Problem being is that you think there is a problem with the battery, when infact the battery is OK. When you have a good fully charged battery in the bike and press the e-start, it turns over very slowly.
      I have checked the electrical circuit and it seems OK. I am wondering if it might be the starter itself - any suggestions?????
    • By Dust_Devil
      I'll start, if you see the "Fox Sticker" out in the Dez you know you crossed paths with ol' DD.....
    • By JohnnyAirtime
      Guys and Gals...
      Post your links to any of your pictures in this thread....
      (proper placement of pictures is in the "picture" threads)
      Post your links to any of your ride reports in this thread....
      (proper placement of your ride reports is relative to the area you live/ride)
      NO TECHNICAL issues, questions or comments in this thread.
      (it'll be deleted to keep this thread clean and with only the above listed).
      Please follow this format;
      Ride Report: Gorman, Tuesday 4-17
      (by Skoot22)
      Pictures from Ride: Baja 4.14.07
      (by Johnnyairtime)
    • By dakynz
      Guys, because of a member ban the jetting database has been removed. Let's start a new one to get this great information created into a sticky for everyone's benefit. Please stick to the information below.
      Temperature Range:
      Smog (AIS):
      Airbox Modified Top:
      Airbox Modified Sides:
      Backfire Screen:
      Air Filter:
      Pilot Jet:
      Main Jet:
      Needle Clip Position:
      Fuel Screw Type:
      Fuel Screw Setting:
      AP Modified:
      Leak Jet:
      AP Cover:
      Exhaust Type:
      Exhaust Modified:
      Pink Wire Modified:
    • By 2can
      I've studied the Jetting sticky's but still have a number of questions:
      I bought my '06 a couple of years ago and had a smog block-off kit installed and the pilot jet was upsized to a 48 and the air box opened up top only. The bike has appeared to run a little lean at times and got hot on a couple of occasions in elevation and on one other occasion. I'm looking at upping the main jet to either a 165 or 170 to help with the possible lean condition. The bike currently has a 142 main jet in it which I believe is the stock size. It looks like the most widely used Needle Jets are the JD Red, but it doesn't look like they are sold separately, is this correct?
      I was going to also get a 45 pilot to have options for further tuning. My assumption is that every bike is a little different and that where you ride is going to have a lot to do with jetting. We ride mostly, mojave desert, baja, and southern Utah with elevations from sea level to 9,000 feet but the higher elevations are generally for a short period as we generally continue through the peaks and head back down.
      I'm looking to convert from a stock exhaust to possibly an FMF Q4. I want something a little throatier but not overly loud and will provide a balanced flow of intake/exhaust.
      So can I get the JD Red Needle Jet by itself or can I get by using the stock and move the clip and be just as happy. I'm just looking to enhance overall performance of the engine and maintain reliability.
