Longer gear shift lever for big foot
I'm looking for a longer gear lever to allow my size 14 (US) boot to fit under more easily.
I have already moved the lever 2 splines and it still isn't good enough.
Does anyone make a longer or different shape lever or should I have it cut and welded to suit?
I assume the stock one is aluminium??
moose makes extended levers as well.
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
