jetting with full yosh 3x mod? is busy
help,im heading to precision to drop the dj kit but need proper jetting suggestions.(burned?)the search function is jacked right now and as usual i need to know soon as possible to get my bike back....any help is greatly appreciated.
Need to know what else you have done to the bike and what altitude you live. Without info can't help.
Well if this helps. I have the Yosh SS, 3X3 and I use the 142.5 and 25 mj with 2.5 out @ Sea level.
sea level, full yosh rs, 3x3, k&n filter, dj kit. and i guess the dj doesnt have a big enough main jet? and do i use dj needle?
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
