DR350SE squeaky suspension
I have a 95' DR350SE with the stock suspension. We you push down on the rear suspension I get a squeaking sound. I was told by someone that it was due to the polyurethane bushings on the linkage. If that is the case can I just lube the bushings, and if so with what kind of lube. Or do I need to replace something.
I have lubed all of the grease fittings in the area of the linkage.
99se and mine does it to. Im sure it needs some work. I grease all the zerks on a regular basis but dont take everything apart because Im to busy having fun on it.
Could it be the same problem as on DR 650's? Check if the muffler clamp bolt is too long and rubbing on the rear suspension coil spring.
