BT45 Sizing
Need help on what size Bridgestone BT45 tires will go on my stock DRZ-400S rims. Can someone give me the best size to run both front and rear. Thanks.
Bridgestone fittment guide here.
Never mind, here it is.
BT45 Front 90/90 x 21 54H pressure 2.4 bar
BT45 Rear 120/80 x 18 65V pressure 2.5 bar
Let me know how they work, as I am desperate for new tyres, only got
1 mm of tread left on the rear Distanzia.
Neil. :excuseme::bonk::busted:
Please let us know how these work. I'm looking for street treads for a an S too!
Thanks Neil, Looking at the following sizes are listed:
$66.95 Bridgestone BT45H 90/90H21 Front Tire Mfg.#: 048765
$79.95 Bridgestone BT45V 120/90V18 Rear Tire Mfg.#: 072621
--- OR ---
$66.95 Bridgestone BT45H 120/80H18 Rear Tire Mfg.#: 066249
Is it okay to mix the H rated and V rated tires? These tires are tubeless, do I still run tubes on the stock S rims with these tires?
06 DRZ-400S
yep, still run tubes.
  • Similar Content
    • By Markl5557
      So I am going to put in an in-line fuel filter just for added protection from stuff in my gas .... and I have always used bronze element cone ones you no what I’m talking about the ones everyone seems to use but upon reading online supposedly that bronze element breaks down and doesn’t catch everything .... I have came across a moose fuel filter that has a fine nylon mesh just like what’s on the petcock filter ... any opinions on which is better ? Bronze element or mesh ?
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
