K&N VS UNI
The guys & gals that race Grand National Championship Flattrack trust the K&N filters on their $12,000 engines. If that's good enough for them, it's good enough for me. A K&N with an water proof Outerwears brand pre-filter cover works just fine for me. You can not cross seat deep creeks, but for dry / semi dry riding, they work.
i have heard that if you dont clean the K&N filter right you can burn up you engine
somebody at the bike shop close to me said lots of people dont clean them right and the paper collapses and lets no air in id go uni
Yeah go with the Uni, or even a TwinAir. K&N is crap to clean, crap when it has the slightest amount of dirt on it, crap at altitude and usually just plain crap. My brother has one on an XR4 and he has to clean it every ride, otherwise we don't usually end up making it up the mountain unless he has the throttle cracked open the whole time. IMHO, foam is way better.
I run K&n on everything including my cars, if you buy their cleaning kit it's not bad to clean. I run mine without an air box on the 100 so it needs cleaning pretty frequently but they aren't supposed to lose effectiveness until the debris is 1/4 thick.As mentioned before the disadvantage to them is water, if they get wet you can't wring it out. Also they're gauze not paper so i don't know what that dealer was talking about, mine's been run over squished and pulled back out and it's fine. I read an article years back by David Vizard who did an independent filter test and a "leading" foam filter company threatened to sue if he published the results with their name. If you don't know his name he's a very respected Chevy r&d guy with money behind him.
Well I did a google search for "Air Filter Testing" and read the articles... I have read his oil filter articles as well...
My opinion has not changed... K&N are fine... they are better than foam filters on filtration and flow...oh and that makes them better than stock since they are foam... the only other better filters are paper... and they don't make those for our bikes.
Like Mike said if GNC tuners trusts them on their $15-20k motors... then so do I...
One more thing... rebelman83 said "i have heard that if you dont clean the K&N filter right you can burn up you engine somebody at the bike shop close to me said lots of people dont clean them right and the paper collapses and lets no air in id go uni"
If the filter won't let air through it would make it stall for lack of air... too much air will burn up a motor... tell you mech. to stop smoking the weed and that he needs more fresh filterd air... :-)
any filter as long as it is oiled properly and sealed properly will work. Ive only seen problems when riding in extreme dust conditions and the filter gets caked up to the point it is easier to draw air around the filter instead of thru it. If its sealed well and has enuf pressure in its holding device they all work. As to which to use, well KN may give more power, but I think a foam is safer. Been on bikes for 40 yrs and never had a failure with a foam and have only used a KN on a couple of 4st and had no failures there either.
I have a K&N Filter on my XR400 and my Ford F150. I have a UNI on my Son's KLX110 and his XR50 we used to own. They all work great. My impressions are the K&N needs more cleaning but provides more flow when clean. The UNI works better in wet and mucky conditions. You won't go wrong with either.
