Valve adjust,what's been your expereince?
I've checked the valves on my 05 wr450,440mi both ex valves check .15mm no problem I have the shims to bring back to spec.All 3 in valves check a slightly loose .10mil(min tol) has anyone shimmed even though they are within spec(albiet on the tight end) I was thinking get the ex valves back in spec,reassemble and run it a few more hundred then recheck? Anybody been in the same boat?
Thank's for any help.
That's what I would do. Have they moved or is this the first time you checked them?
The reason I ask is because Yamaha valves notorious for not moving at all! :excuseme:
Mine haven't moved one little bit on both my bikes, and that is after about 3,000 miles on both.
The reason I ask is because Yamaha valves notorious for not moving at all! :bonk:
First check,bike ran great started fine just wanted to check it out while I have time.With any luck I'll be riding the $hit out of it the next 3 week's or so. Thank's for the reply :excuseme:
This is my first thumper in many years of bikes and I'm watching the valve issue closely.
Yamaha have a great reliable valve system that rarely gives problems.
The valves will impact down during breakin and early miles but as Matty says, you might find they stay put.
I checked mine when I got it from the dealer - the exhaust clearances were in spec but on the tight side - intakes no problem. I was amazed that they come out of the factory like that. But it is an assembly line....
In your case I would just adjusts those that need it as you allude to.
:excuseme:
Remember, in spec is in spec. That's why they have a high and low limit.
No need to worry if on the tight side, unless they have been moving.
I checked my '06 at 15 hours and all 5 were just barely tighter than the tight tolerance. I probably could have run them a while longer as is, but decided to reshim for peace of mind.
My dealer swaps shims for free and has a good assortment, so I was able to bump them all by exactly 5 increments and now are just barely tight of the loose tolerance. Hopefully they will now stay in tolerance for a long time.
Do you have dealer that swaps shims and has lots of sizes? You could bump your intakes by 3 (or whatever) and get all your valve sto the same point in the tolerance range and possibly not have to repeat the reshimming process for a while.
