Are my sprockets good? How long do I have?
Im in the middle of buying parts for my bike, new chain, radiator guards, skid plate, etc...their STOCK sprockets, but they are Sunstar.
I was wondering if I should replace my sprockets, how do they look?
And if I don't replace them will they wear out sooner if I do replace them, so what Im saying is should I just replace them? How long will I get out of them if I don't replace them do you think, will I need to buy a new chain by the time I need new sprockets?
Also, is it recommened to replace them in sets (front and rear) or can you just replace the rear, and not the front (assuming you just want to).
Pics:
pics don't work
ETA: ok, now they work
It's best to replace both sprockets and the chain all together. If you don't, then the old items will just accelerate the wear on the new items.
they look fine
pics don't work
Agreed.
Had picture problems, fixed.
For the time being they look fine. I would replace them though in about a month. When you need to replace one sprocket, the whole drive system needs to go as well...otherwise the wear will accelerate even more.
Doug
They look better than mine. I replace everything at the same time. Also, since you have everything disassembled, it makes it easier. My front sproket is usually OK but since it is the least expensive, I change it as well.
They are about due, mabey a couple rides left in them. If you change anything do them all at once, old parts do bad things to new parts. I put on Primary Drive sprokets and chain from Rocky Mountain MC, half the price of most combo kits and they have worked really well. Go with the O or X ring chain it does make a difference. By the way, "Kuddos" on the bike cleanliness, my bike hasn't looked like that since it came off the showroom floor
Good advise, check the wheel bearings and seals while its apart also.
About due already eh? I only rode it once, the stock chain must beat on these things. Im getting a Regina ORN6 chain.
Pic of the rear could be better...but they don't look too bad from what I can see.
Ill go take new pics.
New pics:
There's some wear that I can see, but LOTS of life left.
I thought that looked new.I will usually go through two good chains before buying new sprockets.Just have to watch how they wear.A worn or stretched chain is what destroys sprockets.Of course sand and mud dont help much so clean em often keep up on the adjustment and light on the oil youll be suprized how long they last.
If its new with only one ride...then you can just replace the chain. A lot of people replace the stock chain (its usually junk) and keep the stock sprockets (AFAMS are good).
They're fine, but be warned, 450s are prone to rip through aluminum sprokets and stretch and non x or o ring chain. (esp when used in MOTOX enviroments).
We know someone who has had many chain and sprocket problems on his 450f. One time the chain broke off some of the knobs or whatever on his rear sprocket and ripped his stock hub in 1/2!!! and at the last race his chain wrapped around his frame because they broke again...renthals to!
Those look good, i wouldn't worry about them. Why are you even posting, you said you've ridden the bike 1 time. Ride it for a year or so than worry about it. Just replace the stock chain. If you dont go o-ring or x-ring the DID ERT 2 is bullet proof. Have fun
Thanks a lot guys. I was just being over cautious I guess. Im getting the Regina ORN6 Chain, I hear GREAT things, and the ERT's and stuff I hear rub agianst the 06 YZ450f's frame because there sooo wide.
