head light bulb
Whats the replacement bulb for the drz400s front light? I have PIAA in all the other bikes and have been happy. Thanks
Standard automotive H4, 55/60 watt I believe.
Well that's what I use.
Neil. :excuseme::bonk::busted:
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
