RM125/250 Fork Oil Specs
Does anyone have the fork oil specs (quantity, range with stock springs and wt.) for an '02 RM250 with KYB boingers. Sorry, I have no manual. Also, our '03 RM125 calls for Suzuki SS-05. Is this 5 wt. oil? Is the Maxima fork oil decent? Thanks in advance.
Fork Oil each leg 454ml or 15.3 us oz. standard.
Manual shows suzuki fork oil L01.....which would probably be 5wt.
I used 5wt in mine and it is good.
Also used the standard quantity also.
It says if you measure your oil level from the top of the fork down, you could have anywhere between 3.15" to 4.72" or 474ml to 434 ml.
Also stock springs are .43mm.
see ya
