2003 Triple clamps on a 2005 YZ250??
Doesn anyone know if a 2003 yz250 upper triple clamp will fit on the 2005?? I bought a 2005 assuming they would, for my pro taper bars and GPR mount, and I can't find anything that says this will work. They are the same diameter forks I believe, but everything I read says only 2004 and 2005 are the same?? Anyone know for sure?? Thanks....
The lower tube diameter went from 46mm in 03 to 48mm in 04 and I believe the upper tube diameter changed to reflect this. I think the 05 AOSS fork retained the 48mm dimension of the 04.
:thumbsup:
